Dynamo not charging
Hello again. Wanted to go to Tesco today, thought I would take the 7. Battery down again, and its just a new one. Voltmeter says 5.8v. Has a battery isolator fitted. Gave her a crank, tested the voltage from the D, and its 7.8-8.1v. The ammeter shows a 10a discharge when I switch on, and wont rise above 0a. I clicked the points on the cut out shut, the ammeter rose from 6a discharge to a 4a discharge. Cant see the cutout working. Any clues would be appreciated.
Dynamo not charging - by Tatenlyle - 26-08-2020, 07:14 PM
RE: Dynamo not charging - by David Stepney - 26-08-2020, 07:50 PM
RE: Dynamo not charging - by Tatenlyle - 26-08-2020, 08:25 PM
RE: Dynamo not charging - by David Stepney - 26-08-2020, 09:00 PM
RE: Dynamo not charging - by Bob Culver - 26-08-2020, 10:45 PM
RE: Dynamo not charging - by Tatenlyle - 27-08-2020, 08:57 AM
RE: Dynamo not charging - by David Stepney - 27-08-2020, 09:09 AM
RE: Dynamo not charging - by Stuart Giles - 27-08-2020, 09:19 AM
