Does Bluecol cause leaks ?
(23-08-2020, 05:20 PM)Reckless Rat Wrote: Ethylene glycol ( blue or green) antifreeze, is thinner than water so it can find weaknesses in your cooling syste.
If there was pink in it before, which is OAT, it's not compatible with ethylene glycol so I hope you flushed it out properly before changing. It's not unusual for the odd leak to appear. I might get shouted down for this, but if the cooling system is in decent order a dose of radweld will usually cure it.
I use a dose of Barr’s Leaks in the cooling system each time I change the coolant. I use a good quality ethylene glycol antifreeze at a 25% mixture.
Does Bluecol cause leaks ? - by morrisminor - 23-08-2020, 05:15 PM
RE: Does Bluecol cause leaks ? - by Reckless Rat - 23-08-2020, 05:20 PM
RE: Does Bluecol cause leaks ? - by John Mason - 23-08-2020, 06:03 PM
RE: Does Bluecol cause leaks ? - by Chris KC - 23-08-2020, 06:45 PM
RE: Does Bluecol cause leaks ? - by David Stepney - 23-08-2020, 07:22 PM
RE: Does Bluecol cause leaks ? - by Steve Jones - 23-08-2020, 09:09 PM
