23-08-2020, 05:20 PM
Ethylene glycol ( blue or green) antifreeze, is thinner than water so it can find weaknesses in your cooling syste.
If there was pink in it before, which is OAT, it's not compatible with ethylene glycol so I hope you flushed it out properly before changing. It's not unusual for the odd leak to appear. I might get shouted down for this, but if the cooling system is in decent order a dose of radweld will usually cure it.
