Clutch slip
I've had something similar, sort of, on my trials car. When setting off at the start of a section the clutch will slip but eventually bite then all OK. Eventually I realised that the release bearing was binding, slightly, on the gearbox nose. In my case no doubt a product of years of trialling, mud and muck and misuse causing wear between the two. Lubrication through the bearing lubricater and working the clutch at the same time solves it and such lubrication has been a pre-event essential for some years.
Clutch slip - by Dave Mann - 19-08-2020, 09:45 AM
RE: Clutch slip - by Alan - 19-08-2020, 09:50 AM
RE: Clutch slip - by David Witton - 19-08-2020, 09:55 AM
RE: Clutch slip - by Ian Williams - 19-08-2020, 09:11 PM
RE: Clutch slip - by Dave Wortley - 20-08-2020, 11:15 AM
RE: Clutch slip - by Tony Griffiths - 20-08-2020, 08:46 PM
RE: Clutch slip - by Alan - 20-08-2020, 10:20 PM
RE: Clutch slip - by Tony Griffiths - 20-08-2020, 11:00 PM
RE: Clutch slip - by Alan - 21-08-2020, 08:46 AM
RE: Clutch slip - by Bob Culver - 21-08-2020, 09:44 AM
RE: Clutch slip - by Tony Griffiths - 21-08-2020, 07:13 PM
RE: Clutch slip - by Alan - 21-08-2020, 08:45 PM
RE: Clutch slip - by Mark McKibbin - 22-08-2020, 01:27 AM
RE: Clutch slip - by Tony Griffiths - 22-08-2020, 02:59 PM
RE: Clutch slip - by Alan - 22-08-2020, 05:34 PM
RE: Clutch slip - by Steve Jones - 22-08-2020, 05:48 PM
RE: Clutch slip - by James Anderson - 22-08-2020, 07:37 PM
RE: Clutch slip - by andrew34ruby - 22-08-2020, 08:50 PM
RE: Clutch slip - by Tony Griffiths - 22-08-2020, 11:10 PM
RE: Clutch slip - by James Anderson - 23-08-2020, 02:45 PM
RE: Clutch slip - by Dave Mann - 12-09-2020, 12:02 PM
