Led lights flickering when off!
(18-08-2020, 09:03 AM)Renaud Wrote: Hi Howard,
As an electronician I would guess it could be a capacitive effect in the lights switch, or either an "antenna" created by the wires to the leds.
The way to discriminate which would be to disconnect the wires from the switch and see if it changes the flickering. If so its the capacitive effect, if not it's the antenna one. Anyway that's just by curiosity but no cure!
To cure I would suppress it by inserting a capacitor (10 nF ceramic 100V) anywhere between each of the concerned circuits and a (good) ground. Probably best to put one on each of the leds so that the connections of the capapcitor are kept VERY short.
Hope this helps.
Renaud
I have hidden an LED in the oil button (as I have a gauge) that works as a telltale for the indicator, it has been flashing when it's not supposed to and I was thinking of putting a resistor across it but a cap is a better idea, Thanks Renaud.
Mark
RE: Led lights flickering when off! - by GK5268 - 17-08-2020, 11:38 PM
RE: Led lights flickering when off! - by Renaud - 18-08-2020, 09:03 AM
RE: Led lights flickering when off! - by Chris KC - 18-08-2020, 11:47 AM
RE: Led lights flickering when off! - by Renaud - 18-08-2020, 11:57 AM
RE: Led lights flickering when off! - by Mark McKibbin - 18-08-2020, 12:17 PM
RE: Led lights flickering when off! - by Renaud - 18-08-2020, 01:35 PM
RE: Led lights flickering when off! - by Chris KC - 18-08-2020, 02:54 PM
RE: Led lights flickering when off! - by Renaud - 18-08-2020, 03:38 PM
RE: Led lights flickering when off! - by Renaud - 18-08-2020, 04:48 PM
RE: Led lights flickering when off! - by Renaud - 20-08-2020, 04:53 PM
