side water branch stud extraction
I once had an engine which had a tight spot when turned by hand.  The cylinders were fitted with liners and one of the side water branch studs was pressing into the liner causing the problem.
side water branch stud extraction - by jamesheath - 14-08-2020, 11:54 PM
RE: side water branch stud extraction - by Malcolm Parker - 15-08-2020, 03:40 PM
