seized spark plugs RP
(14-08-2020, 10:52 AM)Steve Jones Wrote: If you've ever tried to remove an exhaust manifold lambda sensor plug that's been fitted/tightened when it's cold but the manifold is hot you'll have experienced a similar problem. Try removing the plugs with the engine hot.
I don't recall that item ever being on the factory parts list?
c
seized spark plugs RP - by chapelfarmer - 14-08-2020, 07:37 AM
RE: seized spark plugs RP - by John Mason - 14-08-2020, 09:12 AM
RE: seized spark plugs RP - by Ivor Hawkins - 14-08-2020, 09:44 AM
RE: seized spark plugs RP - by Mike Costigan - 14-08-2020, 10:40 AM
RE: seized spark plugs RP - by Martin Prior - 14-08-2020, 10:45 AM
RE: seized spark plugs RP - by Steve Jones - 14-08-2020, 10:52 AM
RE: seized spark plugs RP - by Hedd_Jones - 15-08-2020, 08:33 AM
RE: seized spark plugs RP - by Charles P - 15-08-2020, 08:47 AM
RE: seized spark plugs RP - by Albert S - 15-08-2020, 09:40 AM
RE: seized spark plugs RP - by Chris KC - 15-08-2020, 10:44 AM
RE: seized spark plugs RP - by Steve Jones - 15-08-2020, 11:09 AM
RE: seized spark plugs RP - by Duncan Grimmond - 16-08-2020, 06:25 PM
RE: seized spark plugs RP - by Alan - 16-08-2020, 07:33 PM
RE: seized spark plugs RP - by Charles P - 16-08-2020, 09:43 PM
RE: seized spark plugs RP - by chapelfarmer - 17-11-2020, 07:00 PM
RE: seized spark plugs RP - by Chris KC - 17-11-2020, 07:07 PM
RE: seized spark plugs RP - by andrew34ruby - 17-11-2020, 07:44 PM
