seized spark plugs RP
Hi John, Have you tried taking them out whilst hot. Take you car for a run to warm the engine up then try removing the plugs whilst still hot. Also rubbing around them with a wire brush may remove some of what is making them tight. If all this fails making a small puddle of diesel fuel around each plug in the same place you usually get the water and leave it over night to soak through. That may release them.
John Mason.
seized spark plugs RP - by chapelfarmer - 14-08-2020, 07:37 AM
RE: seized spark plugs RP - by John Mason - 14-08-2020, 09:12 AM
RE: seized spark plugs RP - by Ivor Hawkins - 14-08-2020, 09:44 AM
RE: seized spark plugs RP - by Mike Costigan - 14-08-2020, 10:40 AM
RE: seized spark plugs RP - by Martin Prior - 14-08-2020, 10:45 AM
RE: seized spark plugs RP - by Steve Jones - 14-08-2020, 10:52 AM
RE: seized spark plugs RP - by Hedd_Jones - 15-08-2020, 08:33 AM
RE: seized spark plugs RP - by Charles P - 15-08-2020, 08:47 AM
RE: seized spark plugs RP - by Albert S - 15-08-2020, 09:40 AM
RE: seized spark plugs RP - by Chris KC - 15-08-2020, 10:44 AM
RE: seized spark plugs RP - by Steve Jones - 15-08-2020, 11:09 AM
RE: seized spark plugs RP - by Duncan Grimmond - 16-08-2020, 06:25 PM
RE: seized spark plugs RP - by Alan - 16-08-2020, 07:33 PM
RE: seized spark plugs RP - by Charles P - 16-08-2020, 09:43 PM
RE: seized spark plugs RP - by chapelfarmer - 17-11-2020, 07:00 PM
RE: seized spark plugs RP - by Chris KC - 17-11-2020, 07:07 PM
RE: seized spark plugs RP - by andrew34ruby - 17-11-2020, 07:44 PM
