(07-08-2020, 10:10 PM)andrew34ruby Wrote: Then the speedo went mad. Sometimes it was ok, then would sweep right around to maximum and back. I'm happy to strip the speedo and fix it, but can it be removed without taking out the instrument panel? I don't really want to undo the choke cable and starter pull wire, and the oils pressure gauge pipe etc etc. Can I get the speedo out on it's own???
I think you probably can. I had to change mine recently but also a broken ignition switch so pulling the panel forward was unavoidable. It is probably worth checking the cable as I believe the flick can be symptomatic of a momentary stick and release.
To keep on topic,  I have been repairing the cracks and splits in the Silverstone's bonnet. Fibreglass resin doesn't hang about at 30+ degrees Centigrade...
RE: What have you done today with your Austin Seven - by Nick Lettington - 08-08-2020, 12:02 AM
Users browsing this thread: 17 Guest(s)
