05-08-2020, 12:44 PM
Maybe try adjusting the worm end float first.
To paraphrase the Green Book: loosen the clamp that connects column to dashboard, remove the locking screw at the column base, slacken the pinch bolt, and, using a "C" spanner, rotate the column in the required direction - in your case, anti clockwise - until the required end play is achieved.
I would back it off a couple of notches and see how it feels.
