Drop arm ball removal
Charles lapping the gears does make a difference. What you are trying to achieve by lapping is to adjust the central portion to take out the play then wear down the section at the end of each lock that is less worn (because of less use on full lock) so that it’s full travel is all warn the same and there is less or no play anywhere along its length.
John Mason.
Drop arm ball removal - by John Mims - 02-08-2020, 07:09 PM
RE: Drop arm ball removal - by John Mims - 02-08-2020, 07:18 PM
RE: Drop arm ball removal - by Bob Culver - 02-08-2020, 08:29 PM
RE: Drop arm ball removal - by Parazine - 02-08-2020, 09:03 PM
RE: Drop arm ball removal - by Tony Press - 03-08-2020, 12:59 AM
RE: Drop arm ball removal - by John Mason - 03-08-2020, 09:26 AM
RE: Drop arm ball removal - by Dave Wortley - 03-08-2020, 10:15 AM
RE: Drop arm ball removal - by Bob Culver - 03-08-2020, 10:16 AM
RE: Drop arm ball removal - by Charles P - 03-08-2020, 11:17 AM
RE: Drop arm ball removal - by John Mims - 03-08-2020, 11:46 AM
RE: Drop arm ball removal - by John Mason - 03-08-2020, 08:03 PM
RE: Drop arm ball removal - by Bob Culver - 03-08-2020, 08:23 PM
RE: Drop arm ball removal - by John Mims - 05-08-2020, 09:07 AM
RE: Drop arm ball removal - by Tony Press - 06-08-2020, 12:14 AM
RE: Drop arm ball removal - by John Mims - 07-08-2020, 11:55 AM
RE: Drop arm ball removal - by Ruairidh Dunford - 07-08-2020, 12:29 PM
RE: Drop arm ball removal - by Howard Wright - 07-08-2020, 07:52 PM
RE: Drop arm ball removal - by Charles P - 07-08-2020, 09:43 PM
RE: Drop arm ball removal - by Tony Press - 08-08-2020, 02:18 AM
