making horn push (SWB steering wheel) from scratch
(01-08-2020, 08:34 AM)Mike Costigan Wrote: The two levers on the 1933-34 application are different; note the position of the flat part of the lever in relation to the centre.
I see you are right! I was just presuming these were bent, but they couldn't line up square unless they were angled different, I can now see.
Tony, presumably with the later set, it IS the same lower lever as the earlier combination?
Here is Ian's diagram if it helps anyone else.
If anyone has a duff/broken/scrap lever but with that upper thread on, please make contact...
RE: making horn push (SWB steering wheel) from scratch - by JonE - 02-08-2020, 04:00 PM
