Chassis Packing
Matt, I would remove the spacing washers from the top hinge and this would raise the back edge of the door. The resultant larger gap in the back of door shut line could be improved by packing UP the body tub over the rear chassis extensions. Just my 2 cents cheers Russell
edit : on further thought IF this results in a "pinched" back of door shut line at the TOP, then add packing on the main chassis rails as well. You are moving the body UP relative to the cow horns, this will drag the windscreen forward, and the trailing edge of the door up. Any packing at the cow horns will result in misalignment of the starting handle to rad shell hole.
now 4 cents worth, cheers
Chassis Packing - by Matt_Harnden - 30-12-2017, 06:27 PM
RE: Chassis Packing - by Matt_Harnden - 31-12-2017, 02:23 PM
RE: Chassis Packing - by squeak - 31-12-2017, 03:41 PM
RE: Chassis Packing - by Matt_Harnden - 01-01-2018, 12:30 PM
RE: Chassis Packing - by Martin Prior - 31-12-2017, 07:37 PM
RE: Chassis Packing - by Matt_Harnden - 01-01-2018, 02:16 PM
RE: Chassis Packing - by JonE - 01-01-2018, 12:53 PM
RE: Chassis Packing - by Matt_Harnden - 06-01-2018, 06:08 PM
RE: Chassis Packing - by squeak - 07-01-2018, 12:30 AM
RE: Chassis Packing - by Phil Kingdom - 07-01-2018, 01:36 AM
RE: Chassis Packing - by Matt_Harnden - 21-01-2018, 07:00 PM
RE: Chassis Packing - by Ruairidh Dunford - 08-03-2018, 09:21 AM
RE: Chassis Packing - by "Slack Alice" Simon - 08-03-2018, 02:40 PM
RE: Chassis Packing - by Matt_Harnden - 13-03-2018, 11:06 PM
