LWB dash switch panel wiring - Quick release, or long leads?
OK, will go for panel flop! And yes, will sort an isolator. I'm going to do all the lighting wiring separately after I have the operational bits in place neatly.
Renaud - presumably if there is a non-Chinese isolator, you are happy not to remove the ground terminal?
RE: LWB dash switch panel wiring - Quick release, or long leads? - by JonE - 25-07-2020, 09:59 PM
