LWB dash switch panel wiring - Quick release, or long leads?
I would go for cables which allow you to flop the panel out just enough to get to the terminal screws, speedo cable etc, not so long as hang down like a festoon below the dash. Also don't bind the cables up close to the panel itself thus restricting access to the terminal itself. I know its not original, but if running 6 volt system, include an earth wire from the battery to all lighting units.
RE: LWB dash switch panel wiring - Quick release, or long leads? - by bob46320 - 25-07-2020, 02:59 PM
