Hot Starting Issues
Hello all,
Apologies if this has been covered elsewhere but I just wanted to pick people's brains for common causes of hot starting issues.
The car is a 1934 Box Saloon and it is very reluctant to restart when still hot, such as in a fuel station. It's not been fitted with a starter motor for some years after the last one went up in smoke and I never felt the need to refit a working one, so I can possibly rule out a voltage drop from the motor? It normally bump starts quite happily (fortunately my local fuel station is on a slope), and generally starts easily from cold on the handle.
I think it's less likely to be a fuel vaporisation issue as it does it year round and the exhaust has some heat shielding.
So the question is what obvious things should I be looking at? I'd slightly assume it's ignition related?
Thanks in advance!
Hot Starting Issues - by RupertW - 24-07-2020, 09:44 AM
RE: Hot Starting Issues - by Terrytuned - 24-07-2020, 10:10 AM
RE: Hot Starting Issues - by Malcolm Parker - 24-07-2020, 10:38 AM
RE: Hot Starting Issues - by RupertW - 24-07-2020, 11:01 AM
RE: Hot Starting Issues - by bob46320 - 24-07-2020, 12:02 PM
RE: Hot Starting Issues - by Bill Dixon - 24-07-2020, 12:28 PM
RE: Hot Starting Issues - by David Stepney - 24-07-2020, 04:32 PM
RE: Hot Starting Issues - by Jeff Taylor - 25-07-2020, 01:21 PM
RE: Hot Starting Issues - by Bob Culver - 27-07-2020, 08:10 AM
