Welding Axle Tubes
We cut & welded the D Type tubes, 200mm out the left and added into the right tube to get an offset for the new single seater.
Expertly done by my engineering mate with a TIG welder, he said it was easy to weld the tube. He also welded up the side shaft, mentioned that the steel was of good quality.
Aye
Greig
Welding Axle Tubes - by Tony Press - 22-07-2020, 12:27 AM
RE: Welding Axle Tubes - by Charles P - 22-07-2020, 12:49 AM
RE: Welding Axle Tubes - by Bob Culver - 22-07-2020, 10:57 AM
RE: Welding Axle Tubes - by Parazine - 22-07-2020, 10:05 PM
RE: Welding Axle Tubes - by dickie65 - 22-07-2020, 10:05 PM
RE: Welding Axle Tubes - by Greig Smith - 22-07-2020, 10:18 PM
RE: Welding Axle Tubes - by Tony Press - 23-07-2020, 12:10 AM
