  • 1 Vote(s) - 2 Average
Smart Diode cut out
Hi Zeto
The terminolgy can get tricky. Whiist not all diodes are used primarily as rectifiers,  the 4 in one diode as the second posting, of which two are used in parallel, is intended primarily as a rectifier so the term is not unreasonable, even if it is not so functioning with a dc dynamo!
At 30 ohms the cutout absorbs a watt plus a tad in the heavy winding whereas a conventional diode absorbing .6v at 10 amps soaks 6 watts......
Smart Diode cut out - by JonE - 13-07-2020, 03:14 PM
RE: Smart Diode cut out - by Ian McGowan - 13-07-2020, 03:59 PM
RE: Smart Diode cut out - by JonE - 13-07-2020, 06:03 PM
RE: Smart Diode cut out - by jansens - 13-07-2020, 07:25 PM
RE: Smart Diode cut out - by Ian McGowan - 13-07-2020, 07:44 PM
RE: Smart Diode cut out - by John Cornforth - 13-07-2020, 07:59 PM
RE: Smart Diode cut out - by Bob Culver - 13-07-2020, 09:23 PM
RE: Smart Diode cut out - by JonE - 13-07-2020, 10:21 PM
RE: Smart Diode cut out - by Bob Culver - 14-07-2020, 03:57 AM
RE: Smart Diode cut out - by Zetomagneto - 14-07-2020, 11:23 PM
RE: Smart Diode cut out - by Bob Culver - 15-07-2020, 06:54 AM
RE: Smart Diode cut out - by andrew34ruby - 15-07-2020, 08:46 AM
RE: Smart Diode cut out - by JonE - 15-07-2020, 09:15 AM
RE: Smart Diode cut out - by JonE - 06-04-2021, 09:20 AM
RE: Smart Diode cut out - by Howard Wright - 06-04-2021, 11:14 AM
RE: Smart Diode cut out - by andrew34ruby - 06-04-2021, 11:27 AM
RE: Smart Diode cut out - by JonE - 09-04-2021, 07:54 PM
RE: Smart Diode cut out - by JonE - 27-04-2021, 08:55 AM
RE: Smart Diode cut out - by Peter Iddon - 27-04-2021, 10:39 PM
RE: Smart Diode cut out - by Bob Culver - 28-04-2021, 01:50 AM
