All the engine builders out there.
My question is what is the major cause of the front bearing lip failure. In use there should be little force on this lip as the clutch pushes forward.
Could it be heavy handed use of hammer and pipe to inset bearings. I use a much less pretty version of Ruairidh's press tool but it saves using the wooden handled spanner.
Adrian.
All the engine builders out there. - by Au5t1n7 - 13-08-2017, 11:40 PM
RE: All the engine builders out there. - by Adrian Payne - 16-08-2017, 12:53 PM
