Bending Plywood
#24
When I made a new seat back for the RN and RP I used 3mm birch faced ply. The outer laminations have the grain running the same way. When you cut it to shape the grain needs to be vertical.
  Each end of the sheet was soaked one end at a time in the shower tray overnight then clamped to the steamed ash corners.
  When dry the corners were screwed in place, job done.
Bending Plywood - by John3528 - 03-07-2020, 05:03 PM
RE: Bending Plywood - by jonblob33 - 03-07-2020, 05:12 PM
RE: Bending Plywood - by Howard Wright - 03-07-2020, 05:18 PM
RE: Bending Plywood - by Chris KC - 03-07-2020, 05:20 PM
RE: Bending Plywood - by Jays - 03-07-2020, 06:06 PM
RE: Bending Plywood - by Douglas Alderson - 03-07-2020, 06:41 PM
RE: Bending Plywood - by Pearls not a Singer - 03-07-2020, 10:21 PM
RE: Bending Plywood - by Derek Sheldon - 03-07-2020, 10:42 PM
RE: Bending Plywood - by DavidL - 04-07-2020, 12:03 AM
RE: Bending Plywood - by Erich - 04-07-2020, 03:26 AM
RE: Bending Plywood - by Malcolm Parker - 04-07-2020, 08:54 AM
RE: Bending Plywood - by Chris KC - 04-07-2020, 08:56 AM
RE: Bending Plywood - by Charles P - 04-07-2020, 09:41 AM
RE: Bending Plywood - by Hugh Barnes - 04-07-2020, 10:11 AM
RE: Bending Plywood - by Nic Wiggins - 04-07-2020, 10:13 AM
RE: Bending Plywood - by Nick Turley - 04-07-2020, 12:11 PM
RE: Bending Plywood - by Steve Jones - 04-07-2020, 12:31 PM
RE: Bending Plywood - by Malcolm Parker - 04-07-2020, 12:41 PM
RE: Bending Plywood - by Bruce Nicholls - 04-07-2020, 12:46 PM
RE: Bending Plywood - by bob46320 - 04-07-2020, 02:09 PM
RE: Bending Plywood - by Steve Jones - 04-07-2020, 02:15 PM
RE: Bending Plywood - by John3528 - 04-07-2020, 06:31 PM
RE: Bending Plywood - by Robert Foreman - 04-07-2020, 06:43 PM
RE: Bending Plywood - by DavidL - 04-07-2020, 07:18 PM
RE: Bending Plywood - by Steve kay - 04-07-2020, 10:01 PM
RE: Bending Plywood - by Martin Prior - 04-07-2020, 10:04 PM
RE: Bending Plywood - by andrew34ruby - 05-07-2020, 05:42 PM
RE: Bending Plywood - by Duncan Grimmond - 05-07-2020, 05:55 PM
RE: Bending Plywood - by Steve Jones - 05-07-2020, 06:14 PM
RE: Bending Plywood - by Reckless Rat - 05-07-2020, 07:50 PM
RE: Bending Plywood - by Duncan Grimmond - 05-07-2020, 08:52 PM
RE: Bending Plywood - by Malcolm Parker - 05-07-2020, 10:08 PM
RE: Bending Plywood - by John3528 - 05-07-2020, 10:27 PM
RE: Bending Plywood - by Charles P - 05-07-2020, 11:14 PM
