Bending Plywood
The secret to bending plywood is to start with a sheet of bendy plywood!   If you go onto the Arnold Laver website there is a section 'Bendy Plywood'.
When I did the seat back in the RL I used a sheet of 4mm birch plywood.  The ends were curved round and I held them in the correct shape with a couple of pieces of wood that hooked over.  I then glued  1" wide strips of the same birch ply around the edges of the curved sections and clamped them on.  In other words the curved edges were laminated to 12mm thick.  When dry the restraining timbers were unhooked and the seat back retained its curved shape.  It will spread slightly but remains flexible. This is an advantage as when you fit it back in the car it holds itself snugly in place.
Laminating layers of birch plywood is by far the easiest way for the amateur to produce a strong curved timber.  Make the strips slightly oversize and when the glue has dried sand it down to the finished size.  The result is very pleasing, a bit like those plywood IKEA chairs!
Bending Plywood - by John3528 - 03-07-2020, 05:03 PM
RE: Bending Plywood - by jonblob33 - 03-07-2020, 05:12 PM
RE: Bending Plywood - by Howard Wright - 03-07-2020, 05:18 PM
RE: Bending Plywood - by Chris KC - 03-07-2020, 05:20 PM
RE: Bending Plywood - by Jays - 03-07-2020, 06:06 PM
RE: Bending Plywood - by Douglas Alderson - 03-07-2020, 06:41 PM
RE: Bending Plywood - by Pearls not a Singer - 03-07-2020, 10:21 PM
RE: Bending Plywood - by Derek Sheldon - 03-07-2020, 10:42 PM
RE: Bending Plywood - by DavidL - 04-07-2020, 12:03 AM
RE: Bending Plywood - by Erich - 04-07-2020, 03:26 AM
RE: Bending Plywood - by Malcolm Parker - 04-07-2020, 08:54 AM
RE: Bending Plywood - by Chris KC - 04-07-2020, 08:56 AM
RE: Bending Plywood - by Charles P - 04-07-2020, 09:41 AM
RE: Bending Plywood - by Hugh Barnes - 04-07-2020, 10:11 AM
RE: Bending Plywood - by Nic Wiggins - 04-07-2020, 10:13 AM
RE: Bending Plywood - by Nick Turley - 04-07-2020, 12:11 PM
RE: Bending Plywood - by Steve Jones - 04-07-2020, 12:31 PM
RE: Bending Plywood - by Malcolm Parker - 04-07-2020, 12:41 PM
RE: Bending Plywood - by Bruce Nicholls - 04-07-2020, 12:46 PM
RE: Bending Plywood - by bob46320 - 04-07-2020, 02:09 PM
RE: Bending Plywood - by Steve Jones - 04-07-2020, 02:15 PM
RE: Bending Plywood - by John3528 - 04-07-2020, 06:31 PM
RE: Bending Plywood - by Robert Foreman - 04-07-2020, 06:43 PM
RE: Bending Plywood - by DavidL - 04-07-2020, 07:18 PM
RE: Bending Plywood - by Steve kay - 04-07-2020, 10:01 PM
RE: Bending Plywood - by Martin Prior - 04-07-2020, 10:04 PM
RE: Bending Plywood - by andrew34ruby - 05-07-2020, 05:42 PM
RE: Bending Plywood - by Duncan Grimmond - 05-07-2020, 05:55 PM
RE: Bending Plywood - by Steve Jones - 05-07-2020, 06:14 PM
RE: Bending Plywood - by Reckless Rat - 05-07-2020, 07:50 PM
RE: Bending Plywood - by Duncan Grimmond - 05-07-2020, 08:52 PM
RE: Bending Plywood - by Malcolm Parker - 05-07-2020, 10:08 PM
RE: Bending Plywood - by John3528 - 05-07-2020, 10:27 PM
RE: Bending Plywood - by Charles P - 05-07-2020, 11:14 PM
