crankcase front cover (nosepiece) changes
Is your bush for 7/8" shaft? The thread looks a bit coarse to me but difficult to tell from a picture.
At one time John Barlow listed the starting handle bush. I think he still does as '29 type brass nut'.
The tolerances on the assembly are quite tight. The peg in the shaft has to rest on the ledge on the nosecone to hold the shaft horizontal and at the same time the collar on the shaft has to reach the bush to make it oil tight. The nut on my car is not screwed fully home and held with Loctite. This is to ensure the peg engages properly.
RE: crankcase front cover (nosepiece) changes - by AustinWood - 02-07-2020, 05:21 PM
