Rubber mounted crankcases
Thanks for that, David. The reason I asked was that my RP should have a bolt down crankcase, but the current engine is a bitsa, with a low frame crankcase dated 1935 (M238xxx) I do however have a spare case from 1933. It's got the rubber mountings but the narrower drillings. It has an engine number at M181xxx so it must be one of the early ones as I reckon it's from September 1933. It was only when I was checking the case over that I noticed the difference in the diameters on the feet.
Rubber mounted crankcases - by Reckless Rat - 25-06-2020, 03:58 PM
RE: Rubber mounted crankcases - by David Stepney - 25-06-2020, 04:25 PM
RE: Rubber mounted crankcases - by Reckless Rat - 25-06-2020, 05:33 PM
RE: Rubber mounted crankcases - by DavidK - 25-06-2020, 06:19 PM
RE: Rubber mounted crankcases - by David Stepney - 25-06-2020, 10:35 PM
RE: Rubber mounted crankcases - by Archivist - 26-06-2020, 08:33 AM
RE: Rubber mounted crankcases - by Reckless Rat - 26-06-2020, 12:33 PM
RE: Rubber mounted crankcases - by David Stepney - 26-06-2020, 03:10 PM
RE: Rubber mounted crankcases - by Reckless Rat - 26-06-2020, 04:01 PM
