24-06-2020, 06:12 PM
I am certain you will find if you look at the drive entry of your speedo that the little square shaft will allow movement left to right.
If that is the case it needs new balls in the bearings. As said elsewhere in this thread David Cochrane supplies them.
To repair as per the article on this thread you need calmness, patience, good eyesight, good lighting and a spotless bench to carry this out.
You can buy a great tool for removing the pointer, here are the details;-
https://www.ebay.co.uk/itm/Watch-Hand-Ha...2749.l2649
Take your time with it - they are delicate!
If doing this worries you, send it to Richfield speedograph they do a great job bearings and a full service costs about £100
http://www.speedograph-richfield.com
Hope you manage sort this out OK
