18-06-2020, 11:00 AM
this is a three speed box I assume, what sort of condition is the release bearing cage in? If you gave set all the levers to the correct height and they are exactly equal, it could be wear in the cage giving you issues, have you checked the bearing and cage thrust faces are running true.
