Back axle pinion shaft conundrum
Do a check measurement of the pinion end six bolt flange to match against the crownwheel position to see if the pinion insertion is correct.
you can also seperate the axle half and insert the pinion to have a visual idea of insertion meshing.
RE: Back axle pinion shaft conundrum - by dickie65 - 15-06-2020, 06:30 PM
