Removing steering arm
Robin. Put the nut back on but don’t tighten it. Just put it on enough to take up all the threads on the nut. Then hit it with a big hammer but this time you have a bigger target and the threads are shielded from damage. Once it starts to move and takes up the slack remove the nut and continue to drive it out. You will find that because it has moved the remainder will come out easily.
John Mason.
Removing steering arm - by Robin Oldfield - 14-06-2020, 04:59 PM
RE: Removing steering arm - by Zetomagneto - 14-06-2020, 05:33 PM
RE: Removing steering arm - by Bill Dixon - 14-06-2020, 06:28 PM
RE: Removing steering arm - by Robin Oldfield - 14-06-2020, 06:55 PM
RE: Removing steering arm - by Tiger - 14-06-2020, 08:24 PM
RE: Removing steering arm - by John Mason - 14-06-2020, 08:27 PM
RE: Removing steering arm - by Bob Culver - 14-06-2020, 08:41 PM
RE: Removing steering arm - by Robin Oldfield - 14-06-2020, 10:28 PM
RE: Removing steering arm - by Robin Oldfield - 15-06-2020, 07:10 PM
RE: Removing steering arm - by Nick Salmon - 15-06-2020, 07:23 PM
RE: Removing steering arm - by David Stepney - 15-06-2020, 07:27 PM
RE: Removing steering arm - by Bob Culver - 15-06-2020, 07:29 PM
RE: Removing steering arm - by spannerman - 16-06-2020, 12:32 PM
