Improving handling
#22
Paul, the simplest way I have found of measuring castor (not camber) angle is to use a digital inclinometer like this
https://www.ebay.co.uk/itm/113955392731
You can zero it by putting it on a straight length of timber lying next to the car then sit it on top of the stub axle (probably remove the screwed brass cap first) and it will tell you the answer.
It may not be 100% accurate but it's cheap, easy, quick and will certainly give you a clue if things are wildly wrong.
I suppose you could use it for camber as well if you really wanted to but let's not complicate matters.
Regards,
Stuart
Improving handling - by Paul Nott - 11-06-2020, 09:03 AM
RE: Improving handling - by Bob Culver - 11-06-2020, 09:42 AM
RE: Improving handling - by Barry Townsend - 11-06-2020, 09:49 AM
RE: Improving handling - by austin - 11-06-2020, 09:50 AM
RE: Improving handling - by robert regan - 11-06-2020, 09:55 AM
RE: Improving handling - by Ivor Hawkins - 11-06-2020, 09:59 AM
RE: Improving handling - by Ian Williams - 11-06-2020, 10:07 AM
RE: Improving handling - by Paul Nott - 11-06-2020, 10:40 AM
RE: Improving handling - by David Stepney - 11-06-2020, 10:56 AM
RE: Improving handling - by Chris KC - 11-06-2020, 11:49 AM
RE: Improving handling - by Paul Nott - 11-06-2020, 12:01 PM
RE: Improving handling - by David Stepney - 11-06-2020, 12:25 PM
RE: Improving handling - by John Mason - 11-06-2020, 03:16 PM
RE: Improving handling - by Nick Salmon - 11-06-2020, 05:31 PM
RE: Improving handling - by Paul Nott - 11-06-2020, 07:47 PM
RE: Improving handling - by Ian Williams - 11-06-2020, 08:43 PM
RE: Improving handling - by Nick Salmon - 11-06-2020, 08:59 PM
RE: Improving handling - by Bob Culver - 11-06-2020, 10:09 PM
RE: Improving handling - by JonE - 12-06-2020, 07:35 AM
RE: Improving handling - by stuartu - 12-06-2020, 10:08 AM
RE: Improving handling - by Ian Williams - 12-06-2020, 10:35 AM
RE: Improving handling - by Bob Culver - 12-06-2020, 10:36 AM
RE: Improving handling - by Paul Nott - 12-06-2020, 02:10 PM
RE: Improving handling - by Ivor Hawkins - 12-06-2020, 04:08 PM
RE: Improving handling - by Hugh Barnes - 12-06-2020, 04:33 PM
RE: Improving handling - by bobthompson - 12-06-2020, 07:30 PM
RE: Improving handling - by Ian Williams - 12-06-2020, 08:52 PM
RE: Improving handling - by Paul Nott - 13-06-2020, 10:16 AM
