Back axle pinion shaft conundrum
As far as I know only Austins used the narrow outer ring Angular Contact bearings.
That seems correct- if the wrong way around the outer rings would be separated.
RE: Back axle pinion shaft conundrum - by Tony Press - 10-06-2020, 02:11 AM
