09-06-2020, 01:52 PM
Hi Paul
My advice would be not to repair that.
The nipple is damaged at the end and the pipe is probably brittle hence the crack.
Why not just simply make a complete new pipe you can buy the pipe and the fittings that you require from our esteemed suppliers.
It's a simple job, satisfying to do, then it won't let you down.
Good luck.
Hope that is helpful.
Good luck.
