Silver soldering advice
Nobody seems to have mentioned that silver solder is available in a range of melting points. If you imagine soldering a tankard, you would use the highest for the side seam, the middle for the base, and the lowest for the handle. So you can chose the one most suitable for the job in hand. Generally called "Hard, Medium, and soft" although I have heard one called "Enamelling"
Silver soldering advice - by Peter Naulls - 06-06-2020, 08:57 PM
RE: Silver soldering advice - by JonE - 06-06-2020, 09:07 PM
RE: Silver soldering advice - by Howard Wright - 06-06-2020, 09:24 PM
RE: Silver soldering advice - by bob46320 - 06-06-2020, 09:24 PM
RE: Silver soldering advice - by Nick Turley - 06-06-2020, 09:35 PM
RE: Silver soldering advice - by Colin Wilks - 06-06-2020, 10:46 PM
RE: Silver soldering advice - by Derek Sheldon - 07-06-2020, 07:04 AM
RE: Silver soldering advice - by JonE - 07-06-2020, 08:11 AM
RE: Silver soldering advice - by Derek Sheldon - 07-06-2020, 08:57 AM
RE: Silver soldering advice - by Stuart Giles - 07-06-2020, 09:27 AM
RE: Silver soldering advice - by Derek Sheldon - 07-06-2020, 09:48 AM
RE: Silver soldering advice - by Duncan Grimmond - 07-06-2020, 12:17 PM
RE: Silver soldering advice - by Stuart Giles - 07-06-2020, 01:44 PM
RE: Silver soldering advice - by Peter Naulls - 07-06-2020, 06:07 PM
RE: Silver soldering advice - by Derek Sheldon - 07-06-2020, 09:04 PM
RE: Silver soldering advice - by Bob Culver - 07-06-2020, 09:04 PM
RE: Silver soldering advice - by Lowespeed - 08-06-2020, 09:27 AM
RE: Silver soldering advice - by Charles P - 08-06-2020, 10:04 AM
RE: Silver soldering advice - by Peter Naulls - 08-06-2020, 06:14 PM
RE: Silver soldering advice - by Steve Clare - 08-06-2020, 07:08 PM
RE: Silver soldering advice - by Derek Sheldon - 08-06-2020, 07:37 PM
RE: Silver soldering advice - by Howard Wright - 08-06-2020, 07:45 PM
RE: Silver soldering advice - by Stuart Giles - 08-06-2020, 07:53 PM
RE: Silver soldering advice - by Peter Naulls - 08-06-2020, 09:00 PM
RE: Silver soldering advice - by Ian Williams - 08-06-2020, 09:38 PM
RE: Silver soldering advice - by Jeff Taylor - 09-06-2020, 06:52 PM
RE: Silver soldering advice - by Parazine - 09-06-2020, 09:41 PM
RE: Silver soldering advice - by Peter Naulls - 09-06-2020, 10:01 PM
RE: Silver soldering advice - by spannerman - 10-06-2020, 03:30 PM
