Opal clutch pedal
When adjusting the pedal position on the shaft it can be a great help if you put a right angled screwdriver in the slot on the left end of the pedal shaft. By this means you can reduce the free travel on the pedal to a minimum, the point at which you are not quite engaging the levers with the thrust race.
Opal clutch pedal - by Chris Farris - 07-06-2020, 12:45 PM
RE: Opal clutch pedal - by Mike Costigan - 07-06-2020, 12:53 PM
RE: Opal clutch pedal - by Nick Salmon - 07-06-2020, 01:10 PM
RE: Opal clutch pedal - by Steve Jones - 07-06-2020, 01:27 PM
RE: Opal clutch pedal - by AustinWood - 07-06-2020, 01:40 PM
RE: Opal clutch pedal - by Robert Leigh - 07-06-2020, 05:30 PM
RE: Opal clutch pedal - by Chris Farris - 08-06-2020, 10:14 PM
