Hub puller specs
(02-06-2020, 09:19 PM)Viteran Wrote: Thanks for the information, do you know where I could get a die or a nut .?
Carbon steel die available here.
https://www.tracytools.com/taps-and-dies...ct_id=1184
(02-06-2020, 09:19 PM)Viteran Wrote: Also what is the name of the thread , I thought it could  be UNEF but it doesn’t quite. match,
Whitworth Form (WF) threads all use a 55 degree thread angle; all UN threads use a 60 degree thread angle.
Hub puller specs - by Viteran - 02-06-2020, 03:19 PM
RE: Hub puller specs - by Ian McGowan - 02-06-2020, 08:37 PM
RE: Hub puller specs - by Colin Morgan - 02-06-2020, 08:49 PM
RE: Hub puller specs - by Ian McGowan - 02-06-2020, 09:06 PM
RE: Hub puller specs - by Viteran - 02-06-2020, 09:19 PM
RE: Hub puller specs - by Zetomagneto - 02-06-2020, 09:39 PM
RE: Hub puller specs - by Stuart Giles - 02-06-2020, 09:42 PM
RE: Hub puller specs - by squeak - 02-06-2020, 11:36 PM
