  • 1 Vote(s) - 5 Average
Charging,?.
#69
It's the one with a sliding mount on the left hand side of the dynamo as you look at it end on. The other two brushes are diametrically opposed and their carbons are twice as thick, so it's the thin one that's the third brush. If I remember correctly, rotating the brush anticlockwise increases the output. There is no need to undo anything (except removing the dust cover if it's still there) the brush should slide with finger pressure. Give the commutator a clean while you're at it with a cloth.
Charging,?. - by David.H - 20-04-2020, 07:26 PM
RE: Charging,?. - by Bill Dixon - 20-04-2020, 08:06 PM
RE: Charging,?. - by David.H - 20-04-2020, 09:18 PM
RE: Charging,?. - by Bob Culver - 20-04-2020, 09:27 PM
RE: Charging,?. - by David.H - 21-04-2020, 07:54 AM
RE: Charging,?. - by Bela - 21-04-2020, 08:56 AM
RE: Charging,?. - by Bob Culver - 21-04-2020, 10:27 AM
RE: Charging,?. - by David.H - 21-04-2020, 12:17 PM
RE: Charging,?. - by Bela - 21-04-2020, 05:00 PM
RE: Charging,?. - by David.H - 22-04-2020, 11:23 AM
RE: Charging,?. - by Peter Clayton - 22-04-2020, 03:44 PM
RE: Charging,?. - by David.H - 22-04-2020, 09:16 PM
RE: Charging,?. - by John Cornforth - 22-04-2020, 10:05 PM
RE: Charging,?. - by David.H - 22-04-2020, 10:28 PM
RE: Charging,?. - by Dave Mann - 23-04-2020, 09:15 AM
RE: Charging,?. - by David.H - 23-04-2020, 11:18 AM
RE: Charging,?. - by Bill Dixon - 23-04-2020, 01:16 PM
RE: Charging,?. - by David.H - 23-04-2020, 08:01 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 05:18 AM
RE: Charging,?. - by Bela - 24-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 24-04-2020, 03:09 PM
RE: Charging,?. - by Bob Culver - 24-04-2020, 09:59 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 11:47 PM
RE: Charging,?. - by Bela - 25-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 26-04-2020, 05:43 PM
RE: Charging,?. - by Bela - 26-04-2020, 06:23 PM
RE: Charging,?. - by David.H - 26-04-2020, 08:25 PM
RE: Charging,?. - by David.H - 27-04-2020, 07:49 AM
RE: Charging,?. - by David.H - 27-04-2020, 12:27 PM
RE: Charging,?. - by David.H - 27-04-2020, 01:57 PM
RE: Charging,?. - by John Cornforth - 27-04-2020, 02:56 PM
RE: Charging,?. - by David.H - 27-04-2020, 11:43 PM
RE: Charging,?. - by David.H - 29-04-2020, 05:06 PM
RE: Charging,?. - by John Cornforth - 29-04-2020, 08:23 PM
RE: Charging,?. - by Bob Culver - 29-04-2020, 09:18 PM
RE: Charging,?. - by David.H - 29-04-2020, 09:35 PM
RE: Charging,?. - by David.H - 30-04-2020, 03:28 PM
RE: Charging,?. - by John Cornforth - 30-04-2020, 08:38 PM
RE: Charging,?. - by David.H - 12-05-2020, 10:21 PM
RE: Charging,?. - by John Cornforth - 13-05-2020, 07:49 AM
RE: Charging,?. - by David.H - 13-05-2020, 08:07 AM
RE: Charging,?. - by David.H - 13-05-2020, 01:55 PM
RE: Charging,?. - by David.H - 13-05-2020, 05:58 PM
RE: Charging,?. - by David.H - 14-05-2020, 11:44 AM
RE: Charging,?. - by David.H - 14-05-2020, 09:57 PM
RE: Charging,?. - by David.H - 15-05-2020, 08:09 AM
RE: Charging,?. - by Greig Smith - 15-05-2020, 06:59 PM
RE: Charging,?. - by A G Wood - 16-05-2020, 12:26 AM
RE: Charging,?. - by David.H - 25-05-2020, 04:54 PM
RE: Charging,?. - by Reckless Rat - 25-05-2020, 05:52 PM
RE: Charging,?. - by David Stepney - 25-05-2020, 07:10 PM
RE: Charging,?. - by David.H - 25-05-2020, 07:49 PM
RE: Charging,?. - by John Cornforth - 25-05-2020, 09:40 PM
RE: Charging,?. - by David.H - 25-05-2020, 09:56 PM
RE: Charging,?. - by David.H - 28-05-2020, 10:33 AM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 10:55 AM
RE: Charging,?. - by David.H - 28-05-2020, 02:02 PM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 02:31 PM
RE: Charging,?. - by David.H - 29-05-2020, 02:13 PM
RE: Charging,?. - by David Stepney - 29-05-2020, 02:37 PM
RE: Charging,?. - by David.H - 29-05-2020, 04:41 PM
RE: Charging,?. - by David.H - 30-05-2020, 03:57 PM
RE: Charging,?. - by David Stepney - 30-05-2020, 06:54 PM
RE: Charging,?. - by andrew34ruby - 31-05-2020, 07:32 AM
RE: Charging,?. - by David.H - 10-06-2020, 08:02 PM
RE: Charging,?. - by Ian McGowan - 10-06-2020, 10:00 PM
RE: Charging,?. - by Reckless Rat - 11-06-2020, 07:58 AM
RE: Charging,?. - by David.H - 11-06-2020, 09:47 AM
RE: Charging,?. - by David.H - 08-07-2020, 06:11 PM
RE: Charging,?. - by Reckless Rat - 08-07-2020, 06:24 PM
