(20-05-2020, 09:15 AM)Ivor Hawkins Wrote: As you have a widened axle on a special, I would take the opportunity to make up a twin shock absorber set up as described in the Austin Seven Companion, which would give you the opportunity to match the added axle width precisely
Is there something special I should watch for? I'm thinking the arm right below the hole with the short links. because if I do the arm above the hole the arm can interfere with the spring clamp.
[Image: b84BQMP.jpg]
[Image: h4OU84a.jpg]
(21-05-2020, 01:59 AM)Bob Culver Wrote: Hi Dellie
i trust the extended track rod is safer than it looks! Would be a Warrant of Fitness fail here
It's widened as well but it looks solid actually. It's just badly stripped of paint.
With kind regards.
Pieter
RE: What have you done today with your Austin Seven - by Dellie - 24-05-2020, 06:30 PM
