This doesn't affect me(much) as I'm here in the US. How does this affect Ulster Reps or things like Hamblin Cadets? It appears that they have not really touched the bodies, only things which substantially change the engine and suspension. So if you are building a special with tube framework and/or independent front suspension, those might not be allowed. If you want to convert your Ulster Rep to a split front axle or possibly convert the single shock absorber to two, that might be an issue.
Erich in cold and wet Seattle
