Petrol tank sender unit float...
Hi, has anyone fitted a midget/sprite sender unit? If so did the Austin gauge work with it. Does the needle swing from side to side when the gage is turned upside down? Just fitted midget sensor but gauge not working although T wire straight to earth & gauge reads full. Any suggestions re a fix or source for a compatible modern gauge would be very welcome.
Thanks. Kevin. BTW. The car is 12v.
RE: Petrol tank sender unit float... - by jonblob33 - 20-05-2020, 07:39 PM
