[Image: C0CiF0V.jpg]
I mounted the shock absorber to the front axis but it's to short about 10 cm. My front axle is widened and the old body had oil based shock absorbers mounted.
Is there a solution or should I make longer arms for it? Does it still work as good as intended?
RE: What have you done today with your Austin Seven - by Dellie - 20-05-2020, 08:57 AM
