Mounting front mudguards Rtc special
Methinks that first of all you'd have to decide wether or not you want those front cycle wings to move along with the steering (which has serious advantages when traveling on wet or muddy  terrain...) or not. If you'd want them 'steering' then you'd be condemned to fabricating some brackets that attach to the hub carriers or the backplates of the brakes which calls for serious abilities. Should you be happy enough with fixed fittings  then life could be easier.  Have a look at this tread https://www.austinsevenfriends.co.uk/for...hp?tid=707
I haven't got detailed pictures of the way the front cycle wings are mounted on my Rosengart unfortunately.. hope you can make something out of these
RE: Mounting front mudguards Rtc special - by Michael D - 19-05-2020, 09:24 AM
