  • 1 Vote(s) - 5 Average
Charging,?.
#55
Main battery negative earth strap goes to the body using the original point under the passenger seat.
I always used a single earth point for accessories on my rally cars, this used with relays for anything with a switch meant that electrical problems were happily non existent, even on 10000 mile marathons to Australia!
I have fitted relays for the dip system as the original switch on the column is tiny!
I will run a reasonably heavy lead to a gearbox stud.....with the isolater switch it is getting a bit crowded round the terminal post
In addition a strap from the block to chassis, although the system does seem to rely on the steel body as it's ground.The control box earth is a short lead to the bulkhead earth point.
One change at a time so I can see if anything works!
Perhaps we should treat a Seven like a fibreglass bodied car! I had a TVR Tamsin once and every wire on the car was black....Originally they had coloured tags by the terminals, but by the time I had it they had all gone beige! Mind you I never had a single electrical problem. OK the headlights went out occasionally. .......!
Thanks for your helpful comments.
David
Charging,?. - by David.H - 20-04-2020, 07:26 PM
RE: Charging,?. - by Bill Dixon - 20-04-2020, 08:06 PM
RE: Charging,?. - by David.H - 20-04-2020, 09:18 PM
RE: Charging,?. - by Bob Culver - 20-04-2020, 09:27 PM
RE: Charging,?. - by David.H - 21-04-2020, 07:54 AM
RE: Charging,?. - by Bela - 21-04-2020, 08:56 AM
RE: Charging,?. - by Bob Culver - 21-04-2020, 10:27 AM
RE: Charging,?. - by David.H - 21-04-2020, 12:17 PM
RE: Charging,?. - by Bela - 21-04-2020, 05:00 PM
RE: Charging,?. - by David.H - 22-04-2020, 11:23 AM
RE: Charging,?. - by Peter Clayton - 22-04-2020, 03:44 PM
RE: Charging,?. - by David.H - 22-04-2020, 09:16 PM
RE: Charging,?. - by John Cornforth - 22-04-2020, 10:05 PM
RE: Charging,?. - by David.H - 22-04-2020, 10:28 PM
RE: Charging,?. - by Dave Mann - 23-04-2020, 09:15 AM
RE: Charging,?. - by David.H - 23-04-2020, 11:18 AM
RE: Charging,?. - by Bill Dixon - 23-04-2020, 01:16 PM
RE: Charging,?. - by David.H - 23-04-2020, 08:01 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 05:18 AM
RE: Charging,?. - by Bela - 24-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 24-04-2020, 03:09 PM
RE: Charging,?. - by Bob Culver - 24-04-2020, 09:59 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 11:47 PM
RE: Charging,?. - by Bela - 25-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 26-04-2020, 05:43 PM
RE: Charging,?. - by Bela - 26-04-2020, 06:23 PM
RE: Charging,?. - by David.H - 26-04-2020, 08:25 PM
RE: Charging,?. - by David.H - 27-04-2020, 07:49 AM
RE: Charging,?. - by David.H - 27-04-2020, 12:27 PM
RE: Charging,?. - by David.H - 27-04-2020, 01:57 PM
RE: Charging,?. - by John Cornforth - 27-04-2020, 02:56 PM
RE: Charging,?. - by David.H - 27-04-2020, 11:43 PM
RE: Charging,?. - by David.H - 29-04-2020, 05:06 PM
RE: Charging,?. - by John Cornforth - 29-04-2020, 08:23 PM
RE: Charging,?. - by Bob Culver - 29-04-2020, 09:18 PM
RE: Charging,?. - by David.H - 29-04-2020, 09:35 PM
RE: Charging,?. - by David.H - 30-04-2020, 03:28 PM
RE: Charging,?. - by John Cornforth - 30-04-2020, 08:38 PM
RE: Charging,?. - by David.H - 12-05-2020, 10:21 PM
RE: Charging,?. - by John Cornforth - 13-05-2020, 07:49 AM
RE: Charging,?. - by David.H - 13-05-2020, 08:07 AM
RE: Charging,?. - by David.H - 13-05-2020, 01:55 PM
RE: Charging,?. - by David.H - 13-05-2020, 05:58 PM
RE: Charging,?. - by David.H - 14-05-2020, 11:44 AM
RE: Charging,?. - by David.H - 14-05-2020, 09:57 PM
RE: Charging,?. - by David.H - 15-05-2020, 08:09 AM
RE: Charging,?. - by Greig Smith - 15-05-2020, 06:59 PM
RE: Charging,?. - by A G Wood - 16-05-2020, 12:26 AM
RE: Charging,?. - by David.H - 25-05-2020, 04:54 PM
RE: Charging,?. - by Reckless Rat - 25-05-2020, 05:52 PM
RE: Charging,?. - by David Stepney - 25-05-2020, 07:10 PM
RE: Charging,?. - by David.H - 25-05-2020, 07:49 PM
RE: Charging,?. - by John Cornforth - 25-05-2020, 09:40 PM
RE: Charging,?. - by David.H - 25-05-2020, 09:56 PM
RE: Charging,?. - by David.H - 28-05-2020, 10:33 AM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 10:55 AM
RE: Charging,?. - by David.H - 28-05-2020, 02:02 PM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 02:31 PM
RE: Charging,?. - by David.H - 29-05-2020, 02:13 PM
RE: Charging,?. - by David Stepney - 29-05-2020, 02:37 PM
RE: Charging,?. - by David.H - 29-05-2020, 04:41 PM
RE: Charging,?. - by David.H - 30-05-2020, 03:57 PM
RE: Charging,?. - by David Stepney - 30-05-2020, 06:54 PM
RE: Charging,?. - by andrew34ruby - 31-05-2020, 07:32 AM
RE: Charging,?. - by David.H - 10-06-2020, 08:02 PM
RE: Charging,?. - by Ian McGowan - 10-06-2020, 10:00 PM
RE: Charging,?. - by Reckless Rat - 11-06-2020, 07:58 AM
RE: Charging,?. - by David.H - 11-06-2020, 09:47 AM
RE: Charging,?. - by David.H - 08-07-2020, 06:11 PM
RE: Charging,?. - by Reckless Rat - 08-07-2020, 06:24 PM
