15-05-2020, 07:48 AM
Hi. Barry
On my RK I fitted a small swivelling arm to the radiator bolt under the cowl. It can be turned forward to support the handle and pushed back for starting. A bit like the leather strap you see on many vintage cars.
On the Brookfields special I had an old starter dog which I drilled through and fitted back to front in the nose cone. It is supported by three 1/4” bolts drilled and tapped through the casing. I then filled the gaps with liquid metal. Remembering to drill a small oil return hole.
