  • 1 Vote(s) - 5 Average
Charging,?.
#51
New Fuel line with Wipac filter now in place. Only a little blood lost! At least I got to drain the tank & will put the fuel through a filter before putting it back. I have found a few of layers of J cloth in the funnel is a good filter, probably works as a Covid19 face mask too !
I think I will have to bite the bullet & take the switchboard apart and give it a good clean....I have done them before, just try not to break off any crumbly Bakelite this time. At least all the wires are clearly & correctly labelled.
If that doesn't work I suppose the dynamo will have to come off and be "Examined" - before that though... with engine running what should I expect as voltage at the terminals? Should I disconnect the wires when testing? I have seen 7-8 volts at the battery in the past, so the fault is just lurking, waiting to be found !
Charging,?. - by David.H - 20-04-2020, 07:26 PM
RE: Charging,?. - by Bill Dixon - 20-04-2020, 08:06 PM
RE: Charging,?. - by David.H - 20-04-2020, 09:18 PM
RE: Charging,?. - by Bob Culver - 20-04-2020, 09:27 PM
RE: Charging,?. - by David.H - 21-04-2020, 07:54 AM
RE: Charging,?. - by Bela - 21-04-2020, 08:56 AM
RE: Charging,?. - by Bob Culver - 21-04-2020, 10:27 AM
RE: Charging,?. - by David.H - 21-04-2020, 12:17 PM
RE: Charging,?. - by Bela - 21-04-2020, 05:00 PM
RE: Charging,?. - by David.H - 22-04-2020, 11:23 AM
RE: Charging,?. - by Peter Clayton - 22-04-2020, 03:44 PM
RE: Charging,?. - by David.H - 22-04-2020, 09:16 PM
RE: Charging,?. - by John Cornforth - 22-04-2020, 10:05 PM
RE: Charging,?. - by David.H - 22-04-2020, 10:28 PM
RE: Charging,?. - by Dave Mann - 23-04-2020, 09:15 AM
RE: Charging,?. - by David.H - 23-04-2020, 11:18 AM
RE: Charging,?. - by Bill Dixon - 23-04-2020, 01:16 PM
RE: Charging,?. - by David.H - 23-04-2020, 08:01 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 05:18 AM
RE: Charging,?. - by Bela - 24-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 24-04-2020, 03:09 PM
RE: Charging,?. - by Bob Culver - 24-04-2020, 09:59 PM
RE: Charging,?. - by Tony Press - 24-04-2020, 11:47 PM
RE: Charging,?. - by Bela - 25-04-2020, 09:16 AM
RE: Charging,?. - by David.H - 26-04-2020, 05:43 PM
RE: Charging,?. - by Bela - 26-04-2020, 06:23 PM
RE: Charging,?. - by David.H - 26-04-2020, 08:25 PM
RE: Charging,?. - by David.H - 27-04-2020, 07:49 AM
RE: Charging,?. - by David.H - 27-04-2020, 12:27 PM
RE: Charging,?. - by David.H - 27-04-2020, 01:57 PM
RE: Charging,?. - by John Cornforth - 27-04-2020, 02:56 PM
RE: Charging,?. - by David.H - 27-04-2020, 11:43 PM
RE: Charging,?. - by David.H - 29-04-2020, 05:06 PM
RE: Charging,?. - by John Cornforth - 29-04-2020, 08:23 PM
RE: Charging,?. - by Bob Culver - 29-04-2020, 09:18 PM
RE: Charging,?. - by David.H - 29-04-2020, 09:35 PM
RE: Charging,?. - by David.H - 30-04-2020, 03:28 PM
RE: Charging,?. - by John Cornforth - 30-04-2020, 08:38 PM
RE: Charging,?. - by David.H - 12-05-2020, 10:21 PM
RE: Charging,?. - by John Cornforth - 13-05-2020, 07:49 AM
RE: Charging,?. - by David.H - 13-05-2020, 08:07 AM
RE: Charging,?. - by David.H - 13-05-2020, 01:55 PM
RE: Charging,?. - by David.H - 13-05-2020, 05:58 PM
RE: Charging,?. - by David.H - 14-05-2020, 11:44 AM
RE: Charging,?. - by David.H - 14-05-2020, 09:57 PM
RE: Charging,?. - by David.H - 15-05-2020, 08:09 AM
RE: Charging,?. - by Greig Smith - 15-05-2020, 06:59 PM
RE: Charging,?. - by A G Wood - 16-05-2020, 12:26 AM
RE: Charging,?. - by David.H - 25-05-2020, 04:54 PM
RE: Charging,?. - by Reckless Rat - 25-05-2020, 05:52 PM
RE: Charging,?. - by David Stepney - 25-05-2020, 07:10 PM
RE: Charging,?. - by David.H - 25-05-2020, 07:49 PM
RE: Charging,?. - by John Cornforth - 25-05-2020, 09:40 PM
RE: Charging,?. - by David.H - 25-05-2020, 09:56 PM
RE: Charging,?. - by David.H - 28-05-2020, 10:33 AM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 10:55 AM
RE: Charging,?. - by David.H - 28-05-2020, 02:02 PM
RE: Charging,?. - by Reckless Rat - 28-05-2020, 02:31 PM
RE: Charging,?. - by David.H - 29-05-2020, 02:13 PM
RE: Charging,?. - by David Stepney - 29-05-2020, 02:37 PM
RE: Charging,?. - by David.H - 29-05-2020, 04:41 PM
RE: Charging,?. - by David.H - 30-05-2020, 03:57 PM
RE: Charging,?. - by David Stepney - 30-05-2020, 06:54 PM
RE: Charging,?. - by andrew34ruby - 31-05-2020, 07:32 AM
RE: Charging,?. - by David.H - 10-06-2020, 08:02 PM
RE: Charging,?. - by Ian McGowan - 10-06-2020, 10:00 PM
RE: Charging,?. - by Reckless Rat - 11-06-2020, 07:58 AM
RE: Charging,?. - by David.H - 11-06-2020, 09:47 AM
RE: Charging,?. - by David.H - 08-07-2020, 06:11 PM
RE: Charging,?. - by Reckless Rat - 08-07-2020, 06:24 PM
