HEAD STUD EXTRACTOR.
#21
(11-05-2020, 05:23 PM)Steve Jones Wrote:
(11-05-2020, 04:28 PM)Charles P Wrote:
(11-05-2020, 03:35 PM)Steve Jones Wrote: The set I've used for a long time is a Sealey AK724. Contains 1/4", 5/16", 3/8" and 7/16" extractors. Each also available individually. Coupled with heat at the base of the stud, pretty much works every time.
steve
Agreed.
I find that using oxy/acetylene and getting a lot of localised heat in quickly works much better than fanning it with a DIY butane torch.
c
Agree, oxy/acetylene rather than a butane torch. The block for my new Ulster engine had studs in a worse condition than those in the original posts and all came out without breakages, manifold studs as well. If you do break a stud, the drill guides as detailed in Woodrow work very well when used with the cylinder head. Simple to make if you have a lathe or know someone who does.
+1 on Oxy-Acetylene. Good and hot then a pair of Vise Grips, tighten slightly first then untighten a bit. Backwards and forwards until you can get near enough 1 complete turn. Then you have a fighting chance but they still will break.....
HEAD STUD EXTRACTOR. - by Rpm - 11-05-2020, 10:04 AM
RE: HEAD STUD EXTRACTOR. - by Rick F - 11-05-2020, 10:55 AM
RE: HEAD STUD EXTRACTOR. - by Colin Wilks - 11-05-2020, 10:56 AM
RE: HEAD STUD EXTRACTOR. - by Robert Leigh - 11-05-2020, 11:21 AM
RE: HEAD STUD EXTRACTOR. - by Renaud - 11-05-2020, 12:36 PM
RE: HEAD STUD EXTRACTOR. - by AustinWood - 11-05-2020, 12:52 PM
RE: HEAD STUD EXTRACTOR. - by Ian McGowan - 11-05-2020, 01:14 PM
RE: HEAD STUD EXTRACTOR. - by Tony Betts - 11-05-2020, 01:37 PM
RE: HEAD STUD EXTRACTOR. - by Chris Garner - 11-05-2020, 02:19 PM
RE: HEAD STUD EXTRACTOR. - by Rpm - 11-05-2020, 02:48 PM
RE: HEAD STUD EXTRACTOR. - by Austin in the Shed - 11-05-2020, 03:16 PM
RE: HEAD STUD EXTRACTOR. - by Steve Jones - 11-05-2020, 03:35 PM
RE: HEAD STUD EXTRACTOR. - by Hugh Barnes - 11-05-2020, 04:23 PM
RE: HEAD STUD EXTRACTOR. - by Charles P - 11-05-2020, 04:28 PM
RE: HEAD STUD EXTRACTOR. - by John Mason - 11-05-2020, 04:46 PM
RE: HEAD STUD EXTRACTOR. - by Zetomagneto - 11-05-2020, 05:10 PM
RE: HEAD STUD EXTRACTOR. - by Steve Jones - 11-05-2020, 05:23 PM
RE: HEAD STUD EXTRACTOR. - by Rpm - 11-05-2020, 08:20 PM
RE: HEAD STUD EXTRACTOR. - by John Mason - 11-05-2020, 09:26 PM
RE: HEAD STUD EXTRACTOR. - by Parazine - 12-05-2020, 10:15 AM
RE: HEAD STUD EXTRACTOR. - by A G Wood - 12-05-2020, 10:59 AM
RE: HEAD STUD EXTRACTOR. - by Bob Culver - 12-05-2020, 11:14 AM
RE: HEAD STUD EXTRACTOR. - by David Stepney - 12-05-2020, 03:05 PM
RE: HEAD STUD EXTRACTOR. - by Chris Garner - 12-05-2020, 03:29 PM
RE: HEAD STUD EXTRACTOR. - by Rpm - 12-05-2020, 05:03 PM
RE: HEAD STUD EXTRACTOR. - by AustinWood - 13-05-2020, 10:00 AM
RE: HEAD STUD EXTRACTOR. - by jonblob33 - 14-05-2020, 08:43 PM
RE: HEAD STUD EXTRACTOR. - by Zetomagneto - 14-05-2020, 10:16 PM
RE: HEAD STUD EXTRACTOR. - by jonblob33 - 14-05-2020, 11:47 PM
RE: HEAD STUD EXTRACTOR. - by A G Wood - 15-05-2020, 04:35 AM
RE: HEAD STUD EXTRACTOR. - by Duncan Grimmond - 15-05-2020, 02:51 PM
RE: HEAD STUD EXTRACTOR. - by Charles P - 15-05-2020, 03:05 PM
RE: HEAD STUD EXTRACTOR. - by austin - 15-05-2020, 04:55 PM
RE: HEAD STUD EXTRACTOR. - by Colin Wilks - 15-05-2020, 05:06 PM
RE: HEAD STUD EXTRACTOR. - by Chris Garner - 15-05-2020, 05:56 PM
RE: HEAD STUD EXTRACTOR. - by Duncan Grimmond - 15-05-2020, 08:56 PM
RE: HEAD STUD EXTRACTOR. - by Charles P - 15-05-2020, 11:26 PM
RE: HEAD STUD EXTRACTOR. - by A G Wood - 16-05-2020, 12:20 AM
RE: HEAD STUD EXTRACTOR. - by squeak - 16-05-2020, 01:17 AM
RE: HEAD STUD EXTRACTOR. - by Colin Wilks - 16-05-2020, 10:50 AM
RE: HEAD STUD EXTRACTOR. - by Zetomagneto - 16-05-2020, 11:44 AM
