    Not exactly Austin Seven related, as the old girl is still in lock-down although we are looking forward to an outing next week if the weather holds up. I have been fiddling with my 1966 VeloSolex 3800 assisted pedal cycle/moped. I have had it for a number of years, having bought in a brocante for £60. It runs but not brilliantly, as it lacked power and wouldn't rev out. I finally discovered a partial blockage in the fuel pick up pipe which hopefully will return it to its normal electrifying performance. The Solex has a 50cc two stroke that turns the front wheel via a roller. The throttle is fully open all the time except when the front brake is applied. An interesting experience for the unwary!
RE: What have you done today with your Austin Seven - by Reckless Rat - 08-05-2020, 07:18 PM
