Inner front wheel bearings
Thanks for the tips, very useful.
The inner bearing was indeed tight and I was worried putting too much force on the inner race.
An AF socket, used as a spacer, fitted the bearing lip to enable me to knock out the bearing.
The bearing looks good, so its wash out and repack as you suggest.
I'm guessing the the inner diameter profile of the spacer washer faces away from the bearing?
Thank you for your time, we have plenty of that in UK at the moment, hence all the A7 jobs getting done!
Inner front wheel bearings - by cwchrisp - 04-05-2020, 03:34 PM
RE: Inner front wheel bearings - by squeak - 04-05-2020, 10:38 PM
RE: Inner front wheel bearings - by Tony Press - 05-05-2020, 01:33 AM
RE: Inner front wheel bearings - by Bob Culver - 05-05-2020, 02:54 AM
RE: Inner front wheel bearings - by cwchrisp - 05-05-2020, 09:29 AM
