04-05-2020, 05:07 PM
I seem to recall that Stuart Rolt built a three bearing engine for father.
If I recall correctly he used an undersize centre shell set. bolted the block onto the engine did up the centre bearing housing then bored the centre shells in line and to size.
I also have a recollection of a second set of shells being done at the same time and being marked top and bottom.
