All the engine builders out there.
(14-08-2017, 07:24 AM)Ian Williams Wrote: Derek no please don't remove material! a heat gun helps enormously, get it right and the bearings pretty much just drop on, you have to work quickly though. A length of studding in the front of the crank, short length of tube, big washer and nut will finish the job!
ian,
Are you talking about warming the bearing ? . I did use the other techniques you suggest. thanks
All the engine builders out there. - by Au5t1n7 - 13-08-2017, 11:40 PM
RE: All the engine builders out there. - by Derek Sheldon - 15-08-2017, 08:01 AM
