Spring on engine mount.
If its a Nippy it should be a rubber mounted crankcase anyway. so spring not needed.
I think the spring theory was for three bearing engines to stop chassis twist twisting the crankcase and miss aligning the crank.
As Ian has said also depends on use.
Spring on engine mount. - by brufsup - 02-05-2020, 07:42 AM
RE: Spring on engine mount. - by Ian Williams - 02-05-2020, 07:47 AM
RE: Spring on engine mount. - by dickie65 - 02-05-2020, 12:59 PM
RE: Spring on engine mount. - by GK5268 - 02-05-2020, 02:10 PM
RE: Spring on engine mount. - by Alan - 02-05-2020, 02:38 PM
RE: Spring on engine mount. - by Charles Levien - 02-05-2020, 03:55 PM
RE: Spring on engine mount. - by Renaud - 02-05-2020, 05:34 PM
RE: Spring on engine mount. - by David Stepney - 02-05-2020, 07:07 PM
RE: Spring on engine mount. - by Tony Griffiths - 02-05-2020, 08:11 PM
RE: Spring on engine mount. - by Ian Williams - 02-05-2020, 09:42 PM
RE: Spring on engine mount. - by Reckless Rat - 03-05-2020, 08:04 AM
RE: Spring on engine mount. - by Renaud - 03-05-2020, 08:18 AM
RE: Spring on engine mount. - by David Stepney - 03-05-2020, 08:54 AM
RE: Spring on engine mount. - by Peter Clayton - 03-05-2020, 10:59 AM
RE: Spring on engine mount. - by Tony Griffiths - 03-05-2020, 11:13 AM
RE: Spring on engine mount. - by John Mason - 03-05-2020, 02:51 PM
