A7 lumps in cylinder bores
Thanks for your replies. The bumps are quite random one is on the valve side, in the second photo it can be seen just below quarter to the o'clock, not in line with any studs, block and head are quite corroded internally. The water manifold area is quite bad and needs a repair plate. I don't think the block has  been sleeved before.
Can you recommend some experienced repairers for this ?
Rough budget would be nice to have.
Thanks
Neil
A7 lumps in cylinder bores - by Neil Hindle - 01-05-2020, 01:57 PM
RE: A7 lumps in cylinder bores - by Rogerfrench - 01-05-2020, 04:17 PM
RE: A7 lumps in cylinder bores - by Ian Dunford - 01-05-2020, 04:55 PM
RE: A7 lumps in cylinder bores - by Tony Betts - 01-05-2020, 05:06 PM
RE: A7 lumps in cylinder bores - by Neil Hindle - 01-05-2020, 06:44 PM
RE: A7 lumps in cylinder bores - by Bob Culver - 01-05-2020, 08:35 PM
RE: A7 lumps in cylinder bores - by Ian Williams - 01-05-2020, 09:05 PM
RE: A7 lumps in cylinder bores - by David Stepney - 02-05-2020, 09:53 AM
RE: A7 lumps in cylinder bores - by Jeff Taylor - 02-05-2020, 12:45 PM
RE: A7 lumps in cylinder bores - by Neil Hindle - 04-05-2020, 06:42 AM
