Query on port-heads
#24
Some may be wondering what all this is about.
Individual pipes are to harness momentum effects and pressure pulse reflections. Because adjacent cylinders fire just half a rev successively, and valves do not open and close at tdc, the next cylinder valve opening robs some beneficial positive pressure filling effect developed  at end of suction stroke of its neighbour. Effects applicable mainly at wide throttle. By making the conditions of all cyls more similar, mixture does not have to be especially rich as determined by the weakest. Nonetheless very many cars had siamesed inlet ports. Can complicate smooth fast idle.
Similarly in the exhaust. Separation of successive firing cyls avoids a positive pressure from a neighbour arriving at end of exhaust stroke just as the last gas exits. This involves grouping the outer cyls and the inner, the latter can be siamesed as on Minis etc. Further separation is an attempt to better develop and harness various timely negative pressure reflections and concentrate  these on one cylinder at a time. Somewhat rpm dependant, and resonant effects can be annoying
Query on port-heads - by Nate M - 30-04-2020, 06:30 AM
RE: Query on port-heads - by Bob Culver - 30-04-2020, 07:14 AM
RE: Query on port-heads - by Ritchie Wilson - 30-04-2020, 08:08 AM
RE: Query on port-heads - by AustinWood - 30-04-2020, 09:05 AM
RE: Query on port-heads - by Mike Costigan - 30-04-2020, 09:34 AM
RE: Query on port-heads - by Renaud - 30-04-2020, 09:52 AM
RE: Query on port-heads - by Austin in the Shed - 30-04-2020, 10:23 AM
RE: Query on port-heads - by Alan - 30-04-2020, 10:26 AM
RE: Query on port-heads - by austin - 30-04-2020, 10:37 AM
RE: Query on port-heads - by Mike Costigan - 30-04-2020, 10:50 AM
RE: Query on port-heads - by Zetomagneto - 30-04-2020, 11:35 AM
RE: Query on port-heads - by Chris KC - 30-04-2020, 11:47 AM
RE: Query on port-heads - by Henry Harris - 30-04-2020, 12:19 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 01:06 PM
RE: Query on port-heads - by Robert Leigh - 30-04-2020, 01:20 PM
RE: Query on port-heads - by Chris KC - 30-04-2020, 01:31 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 02:07 PM
RE: Query on port-heads - by geoffharrison - 30-04-2020, 02:16 PM
RE: Query on port-heads - by Rogerfrench - 30-04-2020, 03:31 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 06:27 PM
RE: Query on port-heads - by Henry Harris - 30-04-2020, 09:15 PM
RE: Query on port-heads - by Chris KC - 30-04-2020, 10:16 PM
RE: Query on port-heads - by Hugh Barnes - 01-05-2020, 08:12 AM
RE: Query on port-heads - by Bob Culver - 01-05-2020, 09:02 AM
RE: Query on port-heads - by Nick Lettington - 01-05-2020, 02:38 PM
RE: Query on port-heads - by Rogerfrench - 01-05-2020, 04:06 PM
RE: Query on port-heads - by Lowespeed - 01-05-2020, 04:18 PM
RE: Query on port-heads - by Archivist - 01-05-2020, 05:38 PM
RE: Query on port-heads - by Nate M - 02-05-2020, 05:02 AM
RE: Query on port-heads - by Jeff Taylor - 03-05-2020, 03:02 PM
RE: Query on port-heads - by Nate M - 04-05-2020, 07:08 AM
RE: Query on port-heads - by Rogerfrench - 04-05-2020, 02:18 PM
RE: Query on port-heads - by Bob Culver - 04-05-2020, 09:46 PM
RE: Query on port-heads - by Nate M - 05-05-2020, 04:47 AM
